Thread: Can someone please check out my first tune
    Apr 2018
    FLOrida
    30
    Thank you for any help.
    If does run, motor not driven on the street yet, only running it garage.
    C5R block
    Callies dragon slayer 4.0" crank
    Comp star rods (made by Callies)
    Weseco pistons -8 cc
    ETP 225cc heads , ported to 232cc by WCCH 2.12 intake 1,94 exhaust valves, .700" lift valve springs
    Cam 255/257 .624/.624 lift on 111 +4
    Super Victor intake
    105mm TB with custom elbow
    Stock rockers
    LS7 lifters
    ported oil pump
    dual roller timing chain
    Fuel
    255L intank pump
    60lb injectors
    custome feed/return lines with regulator
    Tranny
    FLT level 6 with hardened input/output shafts
    Yank SS3600 stall
    SFI flexplate
    Rear
    3.55 gears with 30 spline axles,heavy duty posi unit
    That should do it.
    Aug 2009
    Calibrating
    3,373
    Didn’t look at setup since I’m on my cell.. but sounds like a nice setup, if you need any help with it send me a PM
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Apr 2018
    FLOrida
    30
    Didn?t look at setup since I?m on my cell.. but sounds like a nice setup, if you need any help with it send me a PM
    Thank you, car is going to the body shop so it will be a while before I try to tune it. It's set up for SD.
    https://www.youtube.com/watch?v=aGxjlAhGNeM
    Motor is a GEN3 427 bored to 438?? if I remember correctly
    13,565
    Don't forget to change the cylinder volume from the stock 5.7 size to what you are running now.
