Results 1 to 20 of 29
Thread: My remote tune sucks.
    Dec 2019
    16
    Ok Im new to tuning trying to learn, In the meantime I paid a local tuner to remote tune my car and I think its lean he says its good and wont look at my datalog or fix it he has been avoiding my calls can someone take a look at my datalog and confirm if Im correct or wrong.help needed.hplhelp 2.hpl
    Dec 2017
    767
    Need to post the .hpt tune
    Apr 2018
    605
    Why did you start a new thread... https://forum.hptuners.com/showthrea...ew-please-help...
    The Fuel Trims are adding a ton of fuel at all times so yes it's way lean. I wouldn't even leave my driveway in this shape much less be at WOT. All you have for mods is this: "2011 mustang gt airaid cai, full exhaust and granatelli coil packs" ??
    Please supply more details about the mods.. like what CAI exactly, etc.
    Knock Retard is the reduction or prevention of knock by lowering ignition timing:
    (+) Adding Knock Retard = Reducing Timing. PCM is seeing knock.
    (--) Lowering Knock Retard = Increasing Timing. PCM isn't seeing knock.
    __________________________________________________ ________
    2014 Mustang GT Premium. VMP Gen2R Supercharged with an FTI 3000rpm Converter. JLT, BMR, Steeda, Viking, etc.
    Don't fix it if it ain't broken | Maximum effort gets maximum results
    Feb 2016
    482
    ok u are both wrong its way to rich --- don't give advise if u don't know------ its negative fuel trims taking away fuel
    Jan 2013
    Hawaii
    2,101
    I would say its Lean. The first thing I would suggest is to get some OE coil packs, and check your spark plugs, because of the bank to bank differences. The next thing to check is that you O2 sensors are wired up correctly. MAF and injector data are stock, you could go back to the stock tune and see if that helps. IMO Unless you have some modifications you are not disclosing, the tune is not the issue and changing it will probably not fix what ever the issue is.
    Oct 2016
    Poland
    1,730
    Quote Originally Posted by paulsmithsr View Post
    LMAO
    It's actually LEAN - pedal is 100% and it should enter WOT lambda but it does not - hence it's lean in log 1.
    Log 2 it's actuall not that bad for WOT but it's still not entering power enrichment.
    Dec 2019
    16
    Quote Originally Posted by blackbolt22 View Post
    Dec 2019
    16
    I have the airraid mxp tune required CAI, airraid throttle body spacer, off road x pipe, roush axle backs, and Granatelli Motor Sports 4V Street Fighter Coil Packs.
    Oct 2016
    Poland
    1,730
    Quote Originally Posted by justin_ride View Post
    Throw this POS away, put the stock COP's back on
    Jan 2013
    Hawaii
    2,101
    Those intakes are supposed to be no tune required. If the insert has been removed, multiply the maf transfer by 1.4. Add MAF period to your channels an relog.
    Dec 2019
    16
    I dont have the stocks these where on the car when bought
    Dec 2019
    16
    Quote Originally Posted by murfie View Post
    Dec 2019
    16
    Has no insert. All this stuff was on the car when I bought the car
    Sep 2018
    20
    One thing in here is for sure, your remote tune sucks.
    Also, it is going to targeted fuel it's just taking forever for the o2's to get it there.
    Take it somewhere and have it fixed. You are WOT at 5200 and the lambda is damn near 1.0.
    One last thing, text the guy that sent you this and tell him the internet says to sell his device and take a long walk off a short pier.
    Apr 2018
    605
    Dude the fuel trims are adding 10-30% more fuel. Adding fuel means it's lean. How you figure it's rich??? What would happen if it wasn't adding the 25% fuel or so here as compensation... TA DA!!!
    Don't give advice if you can't read logs correctly.... Most of his log he is POSITIVE fuel trims by a ton not NEGATIVE as you state.
    Sep 2018
    20
    Do not ever give advice again. Please. Pretty please!!!!
    Apr 2018
    605
    Quote Originally Posted by Aking719 View Post
    You only have 8 posts but they are all gold so far my friend... lol /fan
    Dec 2017
    767
    I agree, oem coils only
    Sep 2018
    20
    Sometimes you just have to say whats on your mind..
