Results 1 to 3 of 3
Thread: Oxygen sensor senisitivity/oscillation
    Mar 2019
    37
    Need advice, my OCD is going nuts.
    I have longtubes that merge into an X pipe about 24 inches post collectors. I have upstream bungs at collectors, then have downstream bungs about 8 to 12 inches past upstreams.
    I have my upstream 02 on passenger side in the downstream spot, because the wideband took its spot. When I turn trims on, it oscillates terribly and does not respond well. The other side is fine.
    Can I increase sensitivity on this side, or am I stuck with having another bung welded right next to the wideband? Dont have much room. I want to turn my trims on but cant due to this issue.
    Alex
    13,564
    Can't you just move the wideband to the rear hole?
    It's not that much further and if you have no leaks, the readings on the sensor shouldn't change at all.
    Mar 2019
    37
    I could give it a shot. Im sure it would skew the reading a tad but better than not having any trims!
