Results 1 to 5 of 5
Thread: 2018 Sierra 6.2 gear change
    Jun 2012
    225
    I am going to change my gears from 3:23 to 3:73. This might be a dumb question but the only thing I see I need to change is the gear ratio in speedo programming. Is there more than that or am I all good. Thanks
    13,564
    Under the edit tab, use the gear tire ratio calculator.
    Plug in your new gear ratio and current tire size (it'll be the same), then make sure the auto scale transmission settings box is checked. That way it will move your shift points around for you to make the change smooth.
    Jun 2012
    225
    Thanks I was hoping it was that easy. Where is the auto scale transmission settings box?
    Mar 2011
    Ripley, MS
    1,865
    The Autoscale is in the same Tire/Gear Ratio Wizard. You will see it when you open up the Wizard.
    Jun 2012
    225
