Results 1 to 9 of 9
Thread: Demand Values out of Table Ranges?
    Jan 2020
    5
    Brand new to this so a little slack please. Have a 2013 Mustang running nitrous. Have been able to up the engine rpm to 7500 - nitrous window 3500 to 6200 at WOT. Also taken out some timing from 3500 to 7000 over all tables. All works just swell. Question about what values ecu uses when demand occurs out of range covered by table - rpm max in some table might be 5500 for instance. I am guessing nearest value to demand value is used. Is this correct? Am ordering the Coyote Cookbook and assume that may be enlightening. Banish's book not so much. Thanks for any help.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Essentially most ecus use the last value, now if the value in the table is underlined, you can click it, nd change the values. This is really helpful is situations where a table ends at say 5k rpms, but your turning 8k rpms, you need that table to stssy with you throughout the band, so modifying it decreases resolution, but increases the accuracy up top
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Apr 2018
    605
    Quote Originally Posted by Marine Deuce View Post
    Hmm I was hoping the banish book would be better than the cookbook - does it at least cover auto trans stuff? Can you elaborate or PM me why you didn't think it was enlightening. I have the cookbook.. it's OK.. kind of sanity check or quick reference guide but very outdated at this point.
    Knock Retard is the reduction or prevention of knock by lowering ignition timing:
    (+) Adding Knock Retard = Reducing Timing. PCM is seeing knock.
    (--) Lowering Knock Retard = Increasing Timing. PCM isn't seeing knock.
    __________________________________________________ ________
    2014 Mustang GT Premium. VMP Gen2R Supercharged with an FTI 3000rpm Converter. JLT, BMR, Steeda, Viking, etc.
    Don't fix it if it ain't broken | Maximum effort gets maximum results
    Jan 2020
    5
    Thanks Mike. This is what I anticipated. Nice to have a confirmation.
    Jan 2020
    5
    Nearly nothing on transmissions. Few specifics like table changes followed by datalogs etc., to show results. Mostly just an introduction to EFI systems with a few elementary calculations along the way. He is obviously a bright guy and an update that is more technical would be nice.
    Jan 2020
    5
    Ought to qualify a bit here. Banish has 2 books I think. I have the 2007 advanced tuning one. I see he has an 2009 EFI book that alleges more detail. I have not seen that one.
    Apr 2018
    605
    Thanks for the replies. 2009 is old though. We need a newer one
    At least the cookbook is specific to Coyotes!
    Tuner in Training kareltuning's Avatar
    Dec 2019
    Miami, FL
    24
    The last value in the row is used when out of bounds.
    Jan 2020
    5
    Thanks to all of you for the replies. Nice to get answers quickly - even nicer when they are right.
