Page 1 of 6 12345 ... LastLast
Results 1 to 20 of 102
Thread: HP Tuners Now Offering 2014-2019 Ram & Grand Cherokee Ecodiesel Support
    HPT Employee Darek@HPTuners's Avatar
    May 2018
    Chicago, IL
    125
    2014-2019 Ram & Grand Cherokee 3.0L Ecodiesel
    Introducing support for the 2014-2019 Ram & Grand Cherokee 3.0L Ecodiesel
    An MPVI2 interface will be required along with the latest version of
    VCM Suite beta software. Licensing cost is 4 credits for the ECM and
    an internet connection will be required. ZF8 transmission support for
    these vehicles is also available.
    All 2018+ Jeep Grand Cherokee Ecodiesel and RAM 1500 Ecodiesel vehicles require the Smart Access Cable to tune.
    Note: Vehicles that have been previously tuned may need to be
    returned to stock
    • Click here to purchase an MPVI2
    • Click here to download the latest version of our VCM Suite software
    FCA
    • RAM 1500 3.0L Ecodiesel
    • Grand Cherokee 3.0L Ecodiesel
    For the full VCM Editor Change Log, please see the following link:
    http://www.hptuners.com/help/vcm-editor/changelog.html
    For the full VCM Scanner Change Log, please see the following link:
    https://www.hptuners.com/help/VCM-Sc...changelog.html
    For more information, and to view the latest supported vehicles list, click here.
    Nov 2018
    Aberdeen Washington
    56
    Is there a stock file someone can post so we can check it out?
    2004.5, built 48re, Fass lift pump, s364.5 with a s483 compounds, ARP studs, 103# valve springs, 110hp injectors, 669hp 1075ftlbs
    Tuning Addict
    6,820
    Due to GM not giving two flips about their customers anymore I'm possibly fixing to get a 2020 - I know this says for 19, but will 20's be as easily accessed?
    I assume we can at least adjust timing, fueling and turbo controls?
    ~Greg Huggins~
    Tuning Addict
    6,820
    Does anyone have a stock file they can post?
    Then I talked to a tech at a dodge dealer today in regards to this, but does anyone know if it's as simple as having another ecm with a stock cal that you can swap them out to maintain warranty coverage or are flashes stored in other modules? Does the tcm use a separate module on these that logs flash history?
    ~Greg Huggins~
    Tuning Addict
    6,820
    Ok, so I've got a friend/previous employer that owns a dodge dealership and he had me talk to his SM. Basically he said that it doesn't matter if you use a separate ecm, that Chrysler is pretty much like GM or any of the others now to the point that they poll all of the modules looking for change logs, max recorded pids and so on... He said you could swap an ecm out, but if they actually looked, they would kick it for warranty... Can anyone confirm this for sure?
    Also still really curious in seeing a stock cal if anyone has one.
    ~Greg Huggins~
    Jan 2013
    15
    Does anyone have a file for a 2014 grand Cherokee they might be able to share? id like to see some things before springing for this whole kit. pretty pleeeeeeeease? (I haven't used this software in probably 6-7 years, so want to be cautious about it, would like to play with the trial a bit first)
    This is awesome, been waiting a long time for this.
    Now let me get this straight, is this supported on the 4.4 version or the Beta? Bc a few months ago I was told 4.5 beta version, but seeing it on the list now I?d assume not.
    Also is the PCM modification necessary to read the Eco? Bc I have a early 15 that was built in November 2014.. just wanna get my facts straight before I try to read the ecu again. Dont want to loose my GDE tune they?re had to come by now a days..
    Quote Originally Posted by mistermog View Post
    If I get my 1500 to read this weekend I?ll send you the file. I?ve been waiting so patiently to start playing around with this truck!
    Jan 2013
    15
    just make sure you have the file saved before you do anything, back it up. I always did it in 2 locations just to be safe. (And it looks like you have the have the 4.5 beta for the ecodiesel based on what the web page says. its free download though, so you can have both on board and try them)
    Jan 2013
    15
    So a small update to this, I got a file off a grand Cherokee ecodiesel and tried to open it to see what is available. You cant even open these files in the software without the MPVI2 attached.
    I can send the file to someone if theyd be willing to take some screenshots for me of what all is available. ?
    Tuning Addict
    6,820
    I sent a pm with my email. Just let me know what tables you want to see and whether or not you want them public or not.
    ~Greg Huggins~
    Anyone get a U0100 code after the update and reading the Ecu? That?s what I have, and tried to clear it with the scanner and it won?t clear
    Hey does anyone know how to tell what Map and engine mode the truck is in while driving? Fuel, timing, and boost control all refer to the 8 driving modes, and the scanner does not have a channel for it. So i am hesitant to change anything without knowing what map i'm using.
    And if anyone from HPT can chime in are some of the Channels that do not work eventually going to be sorted out? In particular WB EQ ratio, or at least a Commanded Eq ratio from the truck to reference a aftermarket WB gauge against. And MAF frequency, or in this case microseconds
    Tuning Addict
    6,820
    Dr. Mike is the only one to my knowledge to even offer a wideband that can read lean enough to log a diesel. His wideband recalibration allows something in the neighborhood of a 10ish to 99:1 afr reading... Haven't looked or seen an ecodiesel file yet, but most manufacturers use mode 0,1 and 2 for regular driving, then there will be 1 mode just for cold starts, open loop modes for lugging and of course regen modes. You usually can tell a lot just from turbo and injection timing OE settings then trial and error...
    ~Greg Huggins~
    Advanced Tuner Billf6531's Avatar
    Jan 2004
    Calgary, Alberta, Canada
    606
    In post #1, it states: 'Vehicles that have been previously tuned may need to be returned to stock'. Has anyone successfully read an already tuned Ecodiesel ECU?
    Best regards,
    Bill
    Silver 2003 C5 roadster, M6, Euro red/amber tails, Z06 Ti mufflers, Z06 2 cat H-pipe, Z06 airbox, and HPTuners s/w - available to any Corvette or other GM vehicle in Calgary, and also for Ford and Dodge products, including Cummins
    Tuning Addict
    6,820
    This is supposed to be from hpt as a stock jeep file.
    ~Greg Huggins~
    Yes my truck had been successfully read and I?m GDE tuned
    Jan 2004
    606
    Quote Originally Posted by Smxtmpr34 View Post
    PM'd you a day or so ago.
    Best regards,
    Bill
    Jan 2004
    606
    Anyone have a stock read from a Ram 1500 3.0 Ecodiesel?
    Best regards,
    Bill
    Mar 2009
    Austin, TX
    14
    Quote Originally Posted by Billf6531 View Post
    Here is a 2015 Ram Ecodiesel with the AEM recall tune
