Results 1 to 10 of 10
Thread: HPT shows weird Trans numbers
    Sep 2005
    402
    I got all the Trans issues fixed!!!
    The only Trans problem now, is I will be in:
    P, R, or N
    and
    HP Tuners will show that its in 1st!!!
    When it upshifts to 2, 3, or 4 (by itself might I add )
    HP T will show its in the 2, 3 or 4 gear respectively (it shows what it should).
    Its just weird
    On the road again....
    Im just back on the road again.....
    Advanced Tuner gman4dx266's Avatar
    Jun 2006
    Cape Coral, FL
    860
    You're right about it showing 1st gear even in park and what not. My understanding is that when you log 'trans current gear' or whatever it is, that its NOT 'current gear'. A more appropriate definition should be "Trans predicted gear change" (read: what it thinks it will do next). You can also see it predict/change the gear shown before the car actually shifts. Whether or not thats just the 'desired shift time' taking effect or just that the vcm is thinking about it, i dont know. probably both.
    The only failsafe current gear counter is a combination of (A) Common sense and (B) Counting the times the revs drop. lol
    Sep 2005
    402
    lol
    I usually have to let off my Throttle to get it to shift
    Obviously my shifts are not set right for my 4.10s
    I also need to fix my Desired shift times
    Jun 2006
    Cape Coral, FL
    860
    Quote Originally Posted by slow6
    Not trying to jinx you, but thats what i had to do when i blew up my trans. to get it to upshift. lol
    If you want, i dont know much about it, but you -can- set all your shift times to 0 to disable the adaptive learning. You can try that after getting your upshift pressures right, and see if your 410's act right. Hopefully someone else will slide on over here and provide some more info for you. Good luck!
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    lol
    Post your stock file and I'll look it over for you. With the trans shift torque reduction disabled, that trans won't live long if the shift pressures are too low. Why is the WOT 3-4 set at 1000 rpm?
    Russ Kemp
    Jun 2006
    Cape Coral, FL
    860
    Quote Originally Posted by Russ K
    Probably a good idea to note, that if the pressures are too high, its just as bad.
    Wow I totally didnt see that. Why is it 1000rpm? Thats like starting out in 4th gear when you hit it! Thats good for running 22's in the 1320, nothing more.
    Sep 2005
    402
    Quote Originally Posted by gman4dx266
    Its called "lugging the engine" and will easily destroy bearings
    i have seen the stock and mail order tunes set the 4th gear to 1000rpms.
    i just figured that they didnt mess with it because of hwy driving and at wot most peeps dont lay into it long enough to catch 4th gear.
    i questioned the setting once and was told the the puter will need to see w/e rpm first, then it needs to see the mph point to command the shift. so seeing a min of 1000 enabled the "search/quest" of the puter to look for mph then shift.
    i personally dont believe the concept but im a newbie at trans tuning...learning as i go.
    fwiw
    Jun 2006
    Cape Coral, FL
    860
    Quote Originally Posted by usd2sing
    Guess im not 'most people' then, i hit 4th well past 120. lol
    Personally though, id rethink that 1000 rev shift, just to be careful. Look at some other peoples tunes and get an idea.
    Sep 2005
    402
    I HAD 4.10s in the car... but now they are busted
    so I'm going back to the stock 3.42s today
    I didnt change the trans settings... just changed the gear ratio from 3.42 -> 4.10s
