0411 PCM - LS1 Year:2000 T56
I am exploring ways to use a single stage boost control with a waste gate fitted car. I have not found much on the interweb regarding the 411pcm, without resorting to aftermarket controllers. There are sure to be a few experts here that will know if the CAGS solenoid output will work. Thank you in advance!
Using the CAGS settings for VSS enable/disable of a boost solenoid on a manual car.
Assuming the cars Cags lockout solenoid has been removed and MIL light set to off. I am not sure exactly how the CAGS routine operates behind these settings and if this would even work. For example, issues with shifting down from 4-3.... or 3-2 and back up again.
M6 C.A.G.S. (Computer Aided Gear Selection aka Skip Shift)
The parameters control the Computer Aided Gear Selection (CAGS or ?Skip Shift?) feature of the VCM. It activates a solenoid in the transmission to force shifting to 4th gear under light throttle conditions. If disable TPS is exceeded then the solenoid will not activate.
Disable %TPS: Throttle Position to disable C.A.G.S. routine
Enable Speed: Speed to enable C.A.G.S. routine
Disable Speed: Speed to disable C.A.G.S. routine
Enable Baro: Baro to enable C.A.G.S. routine
Disable Baro: Baro to disable C.A.G.S. routine
Min Coolant Temp: Minimum Engine Coolant Temp required for C.A.G.S. routine
- CURIOUS
