Results 1 to 8 of 8
Thread: Missing calibrations
    Sep 2007
    21
    I've just purchased HPT VCM suite, I want to use with an E40 PCM, I seem to remember there where more calibrations in the idle section in previous versions of the suite, minimum idle speed for example. I also remember reading in the forums that you sometimes you need to contact HPT to get access to all of the available calibrations for E40 PCM, is this the case, i was wondering if i had the VCM suite in basic vs advance mode, but i cant see anything in the drop down menus that shows a toggle?
    ANy help appreciated, in particular I want to look at the adaptive idle calibrations/tables
    28,301
    edit-view-set to advanced
    Sep 2007
    21
    Thank you, I've checked and i am already set to advanced view, are there more tables for the E40 PCM than are currently shown in the VCM suite? Can i get them all in an update?
    Idle RPM Limits (was there previously)
    Adaptive idle overspeed / underspeed
    Idle Overspeed Throttle Closed Delay: Adaptive idle may enable after throttle is closed for this amount of time during idle overspeed.
    Idle Underspeed Throttle Closed Delay: Adaptive idle may enable after throttle is closed for this amount of time during idle underspeed.
    13,598
    Are you sure some of the tables are used on different computers?
    Like P01 or P59's and that the E40 just doesn't use them.
    Sep 2007
    21
    not for all i am not, thats why im asking, and ive seen before that you need to ask if some cals are required
    Sep 2007
    21
    is there any reason why idle RPM limits is no longer showing, it was definitely there before?
    13,598
    Post the file you are working with.
    Potential Tuner Daniel-J's Avatar
    Jan 2020
    Adelaide
    4
    I'd be interested to take a look at that file, too.
