Dealing with my LS3-LSA swap here. LS9 cam, stock blower/pulley, factory LSA injectors on 2bar OS.
Originally just did a quick MAF tune right after the blower install and runs decent but now want to get things ironed out with the VE to see if it helps some transient issues.
Tuning OL SD for now, and my lowest load column on the VE table just won't budge. Scanner is saying up to -15% on decel on the lowest load column, wideband showing .85, make the corrections, wait for rich after flash BS, and still wants the same amount of correction. All 3 VE tables are the same. MAF disabled and even tried unplugging it (I have the IAT breakout) DFCO is off.
I noticed the inj PW bottoms out when this happens, I tried lowering it to stock LS3 injector min PW and still rich. I lowered it to like .5 and it finally went lean on decel, about 1.04-1.09 . Then bringing the VE up in that area looked like it was working but fueling seemed very unstable, maybe went too low on min PW and injectors started to misfire?
Also I double checked with a CTSV and ZR1 tune but both of those have different (higher) min PW settings, aren't they all the same injectors?
Also have a buddy with an almost identical setup with same issue... Open loop, DFCO off, inj PW bottoming out on decel.
I realize I can just ignore that and enable DFCO but I still manage to hit those cells while driving and goes rich right before DFCO kicking in. Most importantly, I'm not going to learn anything by ignoring the issue and masking it with DFCO. Any help or insight is greatly appreciated. Could it be the scaling on my VE table going too low on the load axis? I have it going from 12kpa to 135kpa. Maybe I'll try starting it out at like 20kpa I just don't want to tune the whole thing again since I'm pretty close. I'll try and up load a log when I get to my computer later today.
