So I have a 99 Suburban I have swapped with a 6.0 LS. The Motor is a lq9 with 799 heads. Has a texas speed truck stage 2 cam, tbss intake, warr cable throttle body. Running stock 4l60e trans. I seem to be running good at idle but now that I am trying to get out and tune the ve at higher RPM i noticed it wants to breakup really bad under load and backfire. Looking at my log I noticed that the tps was not registering on my log, am I logging the wrong tps value? would this cause the engine to run incorrectly? I also noticed I have info for the EGR timing adjustment. I am logging the wideband in the egr, would that "kick in" the Egr timing adjustment? I checked the tps at the throttle body and i have a good ground, 5 v reference, and varies the voltage when open and closed on the signal wire. I have not had a chance yet to check the voltage at the computer. Attached are my tune and last log. On the log I have the STFT and LTFT disabled and MAF set to 0 hz. Cat overtemp is turned off as well as DFCO. On a side not is there a way to disable LTFT and STFT in the scanner vs reloading a file every time i want to tune the VE? Also the only DTC I got was a cam position sensor voltage code which I cleared and it stayed off.
