Hello, I?m having problems with a known good trans. It won?t shift Into 3rd or 4th. So, long confusing story short, I have a 2wd computer in a 4wd truck and the transmission only shifts into 2nd and that?s it. the truck is a 2003 Silverado, 5.3, 4wd, 4l60e. The computer came out of a 2003 5.3 2wd. I just did the engine/trans swap so I?m just trying to figure out the source of my problem. Would a segment swap help or are all the tables the same in a 2wd vs 4wd? Also the trans was shifting fine in a 2002 Silverado 4wd. I know the computers are different from 02 to 03, not sure if maybe the vss are different too? The speedometer seems to work just fine. Any help at all would be greatly appreciated. Thanks
