Results 1 to 5 of 5
Thread: No closed loop operation
    Nov 2019
    26
    Hey guys,
    I have a 4.8 LS swapped Landcruiser in the shop. Something peculiar is the system won't go closed loop.
    The O2s display voltage and are brand new but the readiness isn't being set. The rig is speed density with with hptuner SD Enhancement. I tried just setting the OE rom to failover to SD as well but still no closed loop.. I'm sure I just messed something up in the setup. Any help appreciated!
    Both tunes are attached.
    Thanks guys!
    Feb 2017
    Houston Texas
    67
    Try disabling these two codes P1441 P1404
    Nov 2019
    26
    Thanks! Looks like that takes care of those readiness issues but not for the o2s. I think the ~.450v is the problem. That appears to be the open circuit voltage for the 02.
    Feb 2017
    Houston Texas
    67
    Quote Originally Posted by joshua@arcflashllc View Post
    Glad I could help.
    Nov 2019
    26
    Seems like the O2 low inside of the ECU is open and there's basically no signal ground for either banks O2 sensor.. Might try to round up another ECU.
