Results 1 to 2 of 2
Thread: PCM Unlock service now ABS communication problem. Support can you help me out?
    Apr 2016
    NJ
    35
    2020 Jeep Gladiator Sport S
    I sent my pcm in to get unlocked, when I got it back I installed it cleared the codes as instructed and all was well. Then I used the vcm scanner to adjust my tire size and now the ABS and Stability light are on . I also have the smart cable installed
    I pulled 2 engine codes and 2 abs codes
    Engine codes
    P1400 - aftermarket calibration detected / warranty void
    U0418- implausible data received from brake system controller module 1
    Abs codes
    U140E-00 - implausible vehicle configuration data received
    C0078-86 - tire diameter-signal invalid
    I’ve tried emailing support but I only received blank return emails with only a number in the subject line.
    28,268
    You can open a support ticket here https://support.hptuners.com/index.php?/Tickets/Submit
    Our forum is not an ideal spot to post hardware related issues.
