Hey guys. I followed the install insructions on the help file to upgrade to the 2-bar enhanced OS, and also copy/pasted my previous VE map into the sub-100kpa zones. I just installed a Delco 2-bar MAP sensor (part 213-796, cross references to GM 09359409) that was recommended here. Nothing else has changed. But now, the car won't crank and sounds like it's flooding out and I can smell fuel.
Anyone know what the deal is? I need to get this car running ASAP, as I may have to go out of town and need it. Does the Delco 2-bar MAP sensor have a different scale that the default scale on the software (Map sensor linear = 200kpa. Map sensor Offset = 10.33kpa?)
That is the only thing I can think of that would cause it since I didn't touch anything else on the tune, and the tune worked fine on the 1-bar OS....I have attached the file...the car is an '02 Z06 with STS GT32's and 60lb injectors (stock motor.) THANKS FOR THE HELP GUYS!!
