Results 1 to 4 of 4
Thread: Knock sensor relocate on 2001 LS 6.0
    Feb 2020
    Bethpage, TN
    15
    I've installed a 2001 6.0 to replace my customer's blown up 5.3 in an 07 Avalanche. The donor truck didn't have AFM so the brand new knock sensors and harness are in the valley. The original, (2 wire) sensors are located by the motor mounts. I have no bosses on the 6.0 in which to drill and install the 5.3 knock sensors. I'm sort of stuck. Any help would be appreciated.
    Feb 2020
    Delta Ohio
    50
    Don't you think you could use the original locations in the 6.0 and just lengthen the harness to make em reach to the side of the block. Seems like the only option. Are the plug ends the same from 6.0 sensors to 5.3 harness?
    13,565
    How are you getting around the crank trigger differences too..
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Yes, unless you have put the late model cam and crank in, your about to have a really bad day
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
