Results 1 to 12 of 12
Thread: TrackHawk Trans
    Tuner Metraman's Avatar
    Feb 2007
    Belleville Michigan
    88
    TrackHawk Trans
    I've had 2 tuners work my Jeeps tune neither can get my shifts to repeat! Is anyone happy with their shifts I'd like to talk with your tuner.
    May 2016
    1,134
    What do you mean? Rev limiter in 1st or something?
    Feb 2007
    Belleville Michigan
    88
    They all vary
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    What do you mean wont repeat, it shifts good a couple times, then shifts differently, if this is the case the tuner would have had to really jack over the tune. The likely scenario is the trans is wearing, and unable to maintain proper clamping force while shifting. If its the 8 speed i wouldnt be surprised if its beginning to fail
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    May 2016
    1,134
    I have found the 8 speeds to hold up good with a good tune. They are quite strong. Even the 8HP70 can hold up pretty good if tuned so it's not slipping clutches.
    Do you mean different gears shift at different RPM of is it shift quality?
    Dec 2013
    Slidell, La.
    1,015
    The key there is with a tune, stock, these things, have minimal at best pressures to complete proper shifts. They are failing more and more in stock form. My point is how hard was it driven stock, before it was tuned. Damage may have been done before any tune.
    When i see one not able to repeat, its usually mechanical.
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
    May 2016
    1,134
    Yeah. If he means sometimes it shifts fine and sometimes it doesn't in the same gear it definitely could be hurt. Not sure if he just expects to see a shift at exactly the same RPM in every gear though and that's what he's saying.
    Dec 2013
    Slidell, La.
    1,015
    Yes, hes very vague in his description, and when asked to verify, still vague.
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
    Feb 2007
    Belleville Michigan
    88
    My question does anyone have a tuned Trackhawk 800 hp and have it shift 6400 and above consistently?
    May 2016
    1,134
    Yes. I can tune them like that without issue. I usually short shift first a bit on purpose though.
    Feb 2007
    Belleville Michigan
    88
    Quote Originally Posted by ridenrunwv View Post
    What do you charge for a trans tune?
    May 2016
    1,134
    Email me at [email protected]
