Results 1 to 6 of 6
Thread: 6L80 Converter Shudder Issues and shift programming
    Feb 2020
    4
    I have a Transmission shop and just bought the setup for Hp Tuning. I bought it to learn how to tweak everything to get the best shifting out of my units I can for the customers. I am also wanting to change lockup values to get the converters to last long and prevent shudders. What part of the forum should I be in to get some help learning this stuff. Any help would be appreciated.
    13,564
    The GM V8 transmission section.
    Raising the lock up speeds and preventing lock up until 4/5th and 6th gears only should help the converter out. I always do that.
    Feb 2020
    4
    You are raising the speed to let it slip more rather than lower to slip less. I could see preventing until 4-5-6 helping fuel mileage at some point.
    13,564
    I meant raising the mph speeds for lock up so it's not "lugging" the converter in the lower gears. I rarely ever touch the slip tables themselves.
    Like I change it so 5th gear lock up can't happen until over 40mph under part throttle and around 45-50mph for 6th gear lock up depending on vehicle.
    Feb 2020
    4
    I will play with that some thanks.
    Advanced Tuner Boost's Avatar
    Dec 2006
    Florida, USA
    303
    those 6 speeds need a new converter for the shudder sometimes
    '12 Caprice PPV 6.0 L77 - daily transportation
    8.7 @ 84 (1/8 mile) bolt-ons
    '02 Silverado RCSB 5.3 L59 - regularly street driven
    8.2 @ 86 (1/8 mile) stock cam and spray
    8.6 @ 84 (1/8 mile) cam and heads no spray
    Our YOUTUBE CHANNEL featuring the Silverado
