Results 1 to 5 of 5
Thread: Does a P59 PCM have some sort of safety cutoff?
    Hey guys, did some searching but couldn't find it. So, I have a P59 computer 4.8 that I just threw a cam in. Everything else is totally stock. But now since I've put the cam in, the computer is killing the motor and the fuel pump signal after a minute or two of running. I haven't touched the tune yet so I think it's possibly some safety cutoff from the bigger cam triggering the knock sensors, but really not sure... Any help would be great! By the way, it's in a swapped vehicle so the VATS is disabled, and I've changed nothing in the tune or sensors or injectors or anything, so not sure where this new problem could be coming from, all I did was pull valve covers and front cover to change cam and this problem started! Thank you.
    Jan 2014
    Waldorf MD
    774
    Post tune file and log
    Daily Driver= 2003 BMW 330xi
    Weekend Cruiser= 2009 Pontiac G8 GT (Vararam, TSP LS3 N/A Stage 1, OBX, CTS-V converter, MagnaFlows w/ J-Pipes, 160 t-stat)
    Project Car= 1991 Chevrolet Camaro RS (LQ4 w/ Gen 4 Rods, LS3 heads, turbo...)
    Truck= 2007 Chevy Silverado 1500 LT LY5 4x4
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    To answer your vague question, with no other information
    no, there isnt
    really just sounds like you need to tune the thing
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Jan 2014
    Waldorf MD
    774
    Quote Originally Posted by mbray01 View Post
    no, there isnt
    Agreed. OP, post tune and log file
    Thanks guys, I actually figured it out and forgot to update, it was because the p0106 wasn't deactivated in the tune, and it was making it cut off for some odd reason
