Thread: Power enrich delay even though there shoudlnt be?
    Baltimore, Md
    1,204
    Can see if doesnt go into power enrich until 4100 rpm/68% pedal/148 kPa even though it should above 25% pedal?
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    Apr 2011
    Chicago, IL
    763
    where do you see the delay happen? during the 1st higher rpm section it hits around 50 tps % @4k which then enables PE and under that you dont go in PE because you havent met the actual tps enable %. the 2nd one hits way sooner because your tps is higher than the 1st one is at that given rpm. the PE tps enable is tps plus idle tps if i remember correctly so if you want it to happen at a lower tps enable you will have to lower the PE enable setting for tps enable. remove 10% and youll see it enter around the 40% mark probably if you repeat that first high rpm section again
    Baltimore, Md
    1,204
    Quote Originally Posted by TCSS07 View Post
    I think i didnt realize I had undid me earlier PE settings in a flash revision. Seems to be a little bit better
    Apr 2011
    Chicago, IL
    763
    yeah its much better this time as it went into pe around 42% instead of 50%. you'll just have to play around with the enable to get it where you want
