I can not find the solution to solve the problems of lack of power and speed and I think it is because the car is protected because it is not normal for a car with 700hp to run like this.
Mercedes, BMW or Audi, they look like planes next to me.
Could someone help me out so I can leave an American muscler car where it deserves?
The modifications on my car are as follows:
BBK Performance full length Camaro headers 1-3/4"
L650182012 Lingenfelter High Flow Camaro ZL1 Cold Air Intake LSA
L250150309 Lingenfelter CTS-V Camaro ZL1 LSA LS9 10 bolt Supercharger Pulley Hub
L220300709 Lingenfelter CTS-V Camaro ZL1 LSA 2.55 8 Rib 10 Bolt Pulley
L960130709 Lingenfelter Supercharger Isolator Coupling LS9 LSA Engine 2009-2014
8PK1655 8 Rib Poly V Belt CTS-V For LPE 2.55 Inch Upper Pulley Lingenfelter.
L310065307 Lingenfelter 160 Degree Thermostat.
Inyector 1050 cc.
Spark plug NKG TR7IX
Oil separator Kit BBK.
Camaro ZL1 35% 10 Rib Overdrive Balancer Pulley Lingenfelter.
Kenne Bell Boost-A-Pump 40 amp - Supercharged.
Attachment 98197Attachment 98198Thank you very much and greetings!
