Results 1 to 5 of 5
Thread: C7 w/A&A supercharger has timing higher then requested - can't get it low enough
    Jun 2018
    609
    C7 with headers and an A&A kit. We are trying to pull timing down to around 11-14 of advance but the car keeps getting around 15-18 and then runs into kr. I'm not sure if it's a mystery table I need to find and reduce the timing or if its from the torque tables. The car is making more eng tq then max eng tq. Every time I raise the vtt both numbers seem to jump up together but the gap does seem to be closing a bit. Problem is the eng tq is up to 900 in the scanner. The car is making good power but no where near that neighborhood. Just put down 540/550 on the dyno. Or could it be the cam advance timing advance. It's a timing table that advances the timing when the cam starts to advance. It's a stock cam running advance at wot so I could see that happening too? I never messed with that table before though.
    Nov 2009
    All Around
    3,149
    best to post the tune
    Aug 2014
    Central, LA
    737
    Either post tune or log with all timing adders/reductors included. I bet you'd spot if you did did that.
    Aug 2009
    Calibrating
    3,373
    Probably cam timing since it adds up top
    Jun 2018
    609
    It was the cam timing guys. I made another pull last night and zeroed out the VCP Spark under wot.
