Results 1 to 18 of 18
Thread: First tune ? stock gen V
    Feb 2020
    Delta Ohio
    50
    I'm beginning to tune with my 14 gmc sierra L83 genV. Hopefully simple question. On a completely stock engine is it necessary to log the MAF or can I just add a percent or two and watch my wideband? Same question for vve tables as far as logging in SD? I'll have to learn more about the torque tables to understand if those would do any good for me to tweak on a stock truck. Any info for beginning steps would be much appreciated.
    Feb 2020
    Delta Ohio
    50
    After thinking about this i'm pretty sure I should leave MAF alone since its aiming for stoich, so I would want to go to PE EQtables to fatten up fuel right? And then maybe a degree or three of timing to start trying to make a little better power from stock tune?
    Mar 2011
    Ripley, MS
    1,865
    You'll find that the MAF and VVE tables are pretty close on a stock truck. You can command the PE to activate at a lower rpm and adjust the PE target for a much leaner WOT AF ratio. Be careful on the timing. These engines don't need much extra timing on pump gas. Add a degree at a time.
    You can increase the DD tables by a small percentage as well. There are some good performance gains to be had by adjusting shift points and shift characteristics as well.
    Feb 2020
    Delta Ohio
    50
    Thanks for the feedback, I'll let u know how things go. Much appreciated
    13,574
    The MAF and VVE don't target stoich. The idea is to use those two side of the airflow model to make it run at stoich. If that means adding fuel or removing fuel from them to get you there.
    The o2 sensors are there to watch what happens and will adjust the fueling needs based on what it see's in the exhaust. Logging the fuel trims will show you what they are doing and how you can adjust things. As well as your wideband, you can log data with that to make your changes.
    Feb 2020
    Delta Ohio
    50
    Is .85 a good eq ratio to aim for in PE on stock set up? Im trying to just learn lambda from the start, heck with afrs...
    Mar 2011
    Ripley, MS
    1,865
    Quote Originally Posted by MrFixIt86 View Post
    Yes, .85-.87 is a good range for the DI engines. I keep mine a little richer at peak torque and slightly leaner at peak hp.
    Feb 2020
    Delta Ohio
    50
    Hell yeah, I can't thank you all enough for the advice. Has anybody figured out a way to be able to grab second gear in a burnout, my truck shuts down if u hit 2 in manual mode with stabilitrac and track cntrl off.
    13,574
    Wire is some sort of switch to the ABS/Stabilitrac/Steering system, to fully disable it.
    Stabilitrac will come back on after 25-30mph even with the buttons set to turn it off.
    Feb 2020
    Delta Ohio
    50
    I thought about the switch in line with a wheel speed sensor or sumn, like simulating a bad speed sensor and disabling the system. I want 2 gear burnouts though lol only one way to find out if it works I guess. Could just unplug the sensor for a rip and try it haha
    Feb 2020
    coral springs , fl
    I think you are in the right direction PE EQ tables is a good start.
    311
    Here is a switch to disable all that LOL
    http://www.tuningbyshanehinds.com/20...itrak-disabler
    Feb 2020
    Delta Ohio
    50
    Ha that is an awesome switch location! I like homebrewing so but i'll do something similar...
    Mar 2020
    I live in georgia, currently working in California
    Im not sure exactly what changed, i have a 2017 Silverado with the l86 and it would never shift out of 1st during burnouts. The other night i tried one and it shifted to 2nd, then 3rd, then 4th.. held on governor for about 10 seconds before i let off.. it was amazing
    Feb 2020
    Delta Ohio
    50
    DUDE THATS WICKED! Lmao, I haven't done the wiring hack yet but id like to know what the heck u stumbled on? I always do burnouts in M1 never tried in D?
    14 GMC sierra 5.3
    few years later, howd ya do on the tune? did you add it to te repository?
    Arizona
    479
    Quote Originally Posted by 383 View Post
    Last Activity 02-19-2021
    he hasnt been here since that date we'll never know
    Sep 2021
    477
    I retuned a 2014 5.3 truck over the weekend that came from another shop who "tuned" the maf. After maf and vve were both back to stock i was getting a very smooth reading on the wideband within 1-2% of commanded.
