Results 1 to 12 of 12
Thread: WOT tuning with Neural Network
    Feb 2020
    38
    Hi guys,
    I have an issue with tuning WOT with NN
    I read a lot of threads in this forum and I'm really thankful for
    The people who shared their experience and knowledge but I ran
    Into issue that I can't figure it out.
    In NN tuning mainly we focus in tuning WOT fueling then taking care of fuel trims finally
    Spark.
    For WOT tuning we set PE ratio + FA stoich = WOT AFR
    If there is EQ Error, we adjusted it with( InjPW vs. Fuel Mass) mutiple by 1.xx richer, 0.xx leaner
    (InjPW vs. Fuel Mass) is inverse of the (InjPW vs. Fuel Mass) table
    So, my car 3.6 charger with CAI and Gutted Cats I Was targeting WOT for high twelve's AFR
    FA Stoich = 0.0688 PE= 0.0100 (the entire table's no blend)
    Total FA for WOT = 0.0788 which equal to 12.7 AFR EXT, COT if off
    So, the issue I can't figure it out the WOT fueling not constant there is Enrichment
    I don't know where is it coming from
    here is what going on with me
    Scanner results:
    -Same tune same file PE=0.100 Theoretically FA=0.0788=12.6AFR
    Run (1)
    Total FA=0.0848 = 11.8, Wideband = 11.8-12.2 AFR, PE was 0.100 and FA Stoich 0.0688 it
    should be 0.0788 why? There is 0.0060 Enrichment!!!
    Run (2)
    Total FA= 0.0826= 12.1, Wideband = 11.9-12.2 AFR Again,same issue
    there is Enrichment!!
    -Tune number (2) PE = 0.0095 = 0.0783=12.7 AFR
    Run (1)
    Total FA = 0.0803 = 12.5, Wideband = 12.3-12.6 AFR again it should be 0.0783?
    Run (2,3 and 4 the same results) and its fine
    Total Fa = 0.783 = 12.7, Wideband = 12.5-12.8 AFR
    That's the issue I ran into it and I can't figure it out
    I noticed when positive STFT B1 appears while WOT and mess up FA ratio
    Wideband result similer to total FA ratio so i assume there is no EQ error I m right?
    -Airflow Max raised
    Any suggestions.?
    update
    i changed injector pulse width today and it seems make it even worse (got EQ error)
    before i have no EQ error at all, commanded total FA in scanner result same as Wideband result
    in previous log i noticed 7% STFT in WOT so, i increased WOT Injpw 5% (1.05) and the result
    Total FA =12.5 AFR and wideband shows 11.5 AFR.
    i think my Issue there is something related to airflow or o2 sensors or i miss something
    any clue?
    816
    Is cat overtemp fueling disabled?
    Feb 2020
    38
    yup COT and EXT is disabled
    Feb 2020
    38
    i think my Issue there is something related to airflow or Fuel trims or i miss something
    any clue?
    Feb 2019
    Owensboro, KY
    266
    STFT will always be moving around alot as that what they do, the weather changes and the stft make quick adjustments based on that information, I only worry about LTFT and try to keep them with + - 5%, If it was me id make adjustment for WOT tuning and get that where you need to and then move back to LTFT and adjust the other half of the injector data to bring this back to where you need them.
    6.4 Whipple Diamond pistons Manley rods, Demon Plus Cam
    Feb 2020
    38
    Quote Originally Posted by FstdodgeKY View Post
    yup this the way to tune with NN
    first WOT and then fuel trims
    but the issue while WOT fuel trims adjust fueling
    i tried to dialed in fueling for closed loop and did't work
    here what i did
    https://forum.hptuners.com/showthrea...el+mass+tuning
    after 2 times of longing and tuning Injpw vs.Fuel mass result in histogram values going bigger % !
    and fuel trims the same
    MY histogram set up:
    LTFT+STFT math :[50114.156] + [50116.156]
    Row : Fuel mass cly 1
    copy and past by % - Half in Injpw vs. fuel mass
    then, copy inJpw vs fuel mass values and past it in row of fuel mass vs injpw
    Feb 2020
    38
    after alot of searching i found old thread had the same issue
    https://forum.hptuners.com/showthrea...tastar-and-392
    Feb 2016
    431
    Just dial the injectors until you achieve the desired afr on wideband as that is what the engine wants.
    Dont fret too much if the Eq number doesn't quite line up, unless you have nothing better to do...its just a number....................
    Feb 2020
    38
    Quote Originally Posted by Hemituna View Post
    yup, desired afr on wideband as that is what the engine wants
    100% result identical but pcm command richer afr sometime
    so, there is nothing i can do
    thank you
    im MAF guy this why i like to keep my result constant 100%
    Sep 2008
    Portersville, Pa
    289
    Unless you have some really aggressive cam's just turn NN back on and tune using the PE for WOT fueling and injector scaling and airflow for closed loop.
    I would not agree with the process of tuning WOT fueling first then closed loop with either NN on or off. If an OBD2 car does not run properly at idle or cruise the last thing you should be doing is going WOT.
    Specializing in building and tuning 1000hp, daily driven, 9 second cars!
    www.ostdyno.com Shop Phone: 724-368-9000
    Feb 2016
    431
    Pretty sure he still is using NN...
    Or as you said, he should be......
    Sep 2008
    Portersville, Pa
    289
    Thanks for the correction. I need to learn to read before I post
