Results 1 to 12 of 12
Thread: 2012 Chrysler 300s cam tune help
    I was brought a 2012 300s to tune after a MDS delete and a small cam was installed. I'm a GM tuner but thought this would be a pretty simple tune. it has not been nothing is the same here these dodges seem to like 0 or negative timing numbers witch makes no since to me. I have been able to get the car to idle pretty stable and run down the road pretty well the problem is it stalls when coming to a stop once in a while and almost every time the car is put into park. when that happens timing goes negative and it stalls. Can any dodge guys provide some incite on what is going on here and how to fix it?
    find below the current tune file and the log of what its doing.
    2001 V6 M5 firebird: drop in K&N, 12bolt with posi and 4.30s, magnaflow muffler, gutted cat.
    9.5 at 73 in the 1/8th on street tires
    Aug 2009
    Calibrating
    3,376
    If I get a moment later I’ll check it out
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    817
    What cam is in it?
    comp 201-300-17
    216/222 @.050
    .520/.515 lift
    114 lsa
    other than the cam/mds delete and rear suitcase mufflers removed the car is stock
    anyone have any ideas?
    anyone have any help? anything at all
    that gave a little insight but that car has a blower on it so alot of the changes he made were for the boost as well as the cam.
    Jan 2020
    I'm running this same camshaft with shorty headers, muffler and MDS delete in a 2011 Ram. I've had the same issue with it dying. I'm an school screwdriver and timing light guy so I'm working through this slowly. So far I've bumped all idle set-points up and disabled the DFCO. That helped a lot. Still working through it all. Are you seeing yours run really rich with this Camshaft?
    Aug 2020
    did you ever find out what this was? or have the file to what fixed it
    Mar 2009
    S. Florida
    582
    Really is a shame people don't come back here and explain what fixed the problem. It becomes TOP SECRET. Little disrespectful for the people that try and help them.
