I was brought a 2012 300s to tune after a MDS delete and a small cam was installed. I'm a GM tuner but thought this would be a pretty simple tune. it has not been nothing is the same here these dodges seem to like 0 or negative timing numbers witch makes no since to me. I have been able to get the car to idle pretty stable and run down the road pretty well the problem is it stalls when coming to a stop once in a while and almost every time the car is put into park. when that happens timing goes negative and it stalls. Can any dodge guys provide some incite on what is going on here and how to fix it?
find below the current tune file and the log of what its doing.
