16 SS M6 Reduced Power
Demauro cut.hplDemauro Final 1.hpt
I tuned this 16 Camaro tuned well makes good power, drives great. BUT when you lay on it in 1st or 2nd you get a "Reduced Performance" " Reduce Clutch Use" message and it drops power then starts to accelerate again. I have tried it in 3rd, 4th, and it hauls as it should. The only thing I wonder about is I did change Revs per mile for 305's the customer installed. Might try swapping back. Is there a channel for non driven tires? Tune and log attached. You can see when it does it the Predicted and Immediate torque goes to unknown in the log. Anyone else run into this?
Thanks, swapped it back to stock revs per mile and its happy. How do we adjust for tire size?
