Results 1 to 3 of 3
Thread: Is it worth it
    Is it worth it
    Going to install lsa supercharger on G8. As it stands... Stock motor...... Bought everything else :... lsa with zl1lid, intercooler,pump, 80#injectors with data, HP gm pump running 58psi , btr pds stage 2 caam, springs, PR trunions etc.
    also bought aem wideband and mpvi2.(no credits yet as hesitant if its worth going there)
    My worry is. I am 600 can$ in between hp tuners and wideband already not counting credits (=+100$).... A professional (if it can be trusted) tune is 1k Canadian as quoted....so 300 more. Nearest tuner is 40miles ..... towing even more$$
    Truth is, I was very disappointed to find nothing in the depository as a base file to work off with. am I doing something wrong while searching. Nobody ever installed a btr pds stage 2 on a 6.0! even a 6.2 e38 .....or even supercharge a 6l ls
    seems like the depository is basically stock files.
    Not looking for a free ride-tune , far from that, but don't seem to find anything to even get me idling-started with the cam. Will I even be able to strt the car with the new cam.
    On side note: since supercharger pulleys are easily interchangeable-swappable on lsa SC (aftermarket hub and pulley).... should one tune with an undersize (2.55) pulley
    and then run a regular 3+ pulley for stre et with no issues or will the different tunes need to be flashed.
    Aug 2009
    Calibrating
    3,371
    You just need someone to help you remote tune
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Feb 2017
    Houston Texas
    67
    Depending on the route you want to take we can help you. Like Ben said you can get a remote tune or you can post your tune with datalogs and we can help you get the car running and get it to your tuner of choice.
