hello i did a dyno pull but even when im cruising my car is bouncing and jerking idk if its the tune or 3700 stall from tci. its about 2000-3000 rpm you can see it jerking and idk how to fix it. any help would be great. made 540 rwhp little rice at 12* so doing good but just need alittle help still. twin turbo 70mm on3 5.3 104mm sheet metal intake custom comp cam. flat top pistons 799 heads. t6 ngk
thanks
Ryan
