Results 1 to 5 of 5
Thread: 300c engine swap
    Apr 2010
    3
    300c engine swap
    hi have a customer that has swapped the 57 from his 300c with a 6.4 srt engine and ecu. the car will start and run for a few seconds then shuts down. is it possible to turn off the security and have the stock srt ecu drive the car ? kel
    Advanced Tuner coanan's Avatar
    Mar 2009
    S. Florida
    582
    Contact these people. http://hotwireauto.com/
    2018 Trackhawk PCM/TCM tune by Dusterhoff.
    Flex Fuel, MMX faux 95mm TB, GripTec 2.85, 10% ATI lower, FIC1200, ARH 1 7/8 w/cats, 180 T-stat
    13 Chrysler 300S, RAM BGE 412 stroker, cam motion 232/246 619/619 118 +4, ATI 18% OD pulley
    Whipple Gen5 3.0, 2.50 upper pulley, Smooth Boost controller, FIC 1200 inj. Nick W 108mm TB, FORE dual return fuel system, E85, FTI 2800 stall(SRT83380), SHR WAR Viking trans and valve body, Getrag 3.73, 1 7/8 kooks w/hi-flow cats, 3" Magnaflow Cat-back 943rwhp
    Quote Originally Posted by brokenecu View Post
    Sounds like you just need the vin programmed in the pcm..
    get a matching skim box key and ecm from the junkyard
    Aug 2019
    Raleigh
    7
    Did you ever solve this issue?
