Results 1 to 2 of 2
Thread: Engine swap
    Feb 2020
    2
    Engine swap
    I am swapping the engine in a 2010 GMC canyon from i5 to 5.3 using a new gm e67 pcm and engine harness. Will I be able to set everything up in the pcm for the swap or will I need to have it flashed on tech2 ? Will I need a vin for a truck that came with the 5.3 to do this ?
    13,564
    A GM tool must flash the computer first with a V8 operating system. You'd need a VIN number from a V8 truck too.
