Results 1 to 10 of 10
Thread: Please analyze/review my current tune!!!
    Feb 2020
    5
    Hey all,
    Brand new user here...never tuned before, and just plugged in the HPT unit a few mins before posting this! The car is new to me, but already had some mods done, and was tuned by a shop in SoCal via HPTuner. I'm wondering if there's any room for tweaking things at all as I begin to learn how this all works. I also run higher octane fuel than what it was tuned for, and opened up the exhaust slightly. I'll try to post all relevant info below. If I forget anything, let me know and I will get you the info quickly. Thank you in advance!
    Car:
    2003 Corvette Z06
    Engine:
    Gen4 LS3 (built by American Heritage Performance)
    Mods/Hardware:
    91 octane fuel (CA car)
    GMPP ported heads, 275cc
    BTR dual valve springs, Ti retainers (.660")
    Comp cam (226/238, .627"/.627", 113 LSA)
    Stock LS3 intake, ported and radius rod-modded
    Stock LS2 throttle body, ported to 92mm (Peak Speed Shop)
    AR long tubes, gutted cats (1 3/4")
    Stock C5Z axle-back
    Stock C6 LS7 MAF and air intake/bridge with K&N
    Current Tune:
    For the above mods/fuel, tune by Church Auto in Wilmington, CA
    Dyno was 493whp/463wtq
    (tune attached below)
    ...as I said, the changes since purchasing are very minor, but I want to tinker and learn how the changes affect things...
    Changes since purchasing:
    1) I run 94 octane fuel instead of the previous 91, so I am wondering if I can bump the timing advance a little?
    2) Changed the axle-back exhaust to freer-flowing, straight-through "bullet" style mufflers
    *3) Not done yet, BUT, I have purchased a full 4" air intake with a 4" MAF tube, and I am looking for info on how to adjust the MAF tables for the new tube*
    ...that's about it! Please let me know if this tune looks typical, and/or if there are any advisable changes for the new fuel octane or anything else. Thanks so much!
    Jul 2012
    Florida
    1,454
    I would not be bumping up the spark tables. You need to lower the values in the low octane table by at least 4 degrees.
    2013 Silverado 5.3, 6L80k 8.8
    Feb 2020
    5
    Really? Almost everything I've read on here and elsewhere says that the common method is to make sure the high and low tables match?
    13,559
    How would the computer pull timing if it did knock then?
    If both tables are exactly the same and there was a knock event, it could pull that amount of timing then it would go away and slam the timing right back in and it could knock again. Having less timing in the low octane tables allows the computer to use the knock learn factor to blend the timing between the high and low if there is knock retard.
    The only time timing should be the same is if you are using a stock operating system and you have to tune speed density with the MAF failed, as that will revert to the low octane table in that case. Upgraded OS's allow you to retain the high/low functions like a stock OS does.
    More timing doesn't mean more power. A dyno would tell you where peak power/torque is. Your timing is already in the upper 20's, going to 30-32 degrees could very well lose you power.
    Do your changes and get a wideband in the exhaust as well as that into your logs so you can watch real time air fuel ratio's. Create a wideband error for the commanded against the actual AFR/Lambda and you can start fixing the MAF curve because of your changes. That error graph will tell you exactly how much you need to change it.
    Wideband tuning is done in open loop with closed loop and fuel trims disabled too.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    My concern is that the knock sensor tables havent been lowered. Everytime ive ever done a gen 4 engine in a gen 3 setup, it has required the knock sensor sensativity to be increased by about 25%.
    Every one i have ever done had the engine rattling like marbles in a coffee can long before it detected knock. The high table looks good for 93, i would lower the low table about 4-6 degrees. Increase knock sensor sensativity till you see it pull timing at the current timing level, then back it down just a touch. Other than that i dont see much to really complain about with a quick glance
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Feb 2020
    5
    I've done a little bit of logging since posting, and there's been 0 timing pulled at any point from knock. It also seems to be running a bit on the rich side. That led me to believe I might be leaving something on the table there, but I'm going to take it to a well-recommended tuner and have them dyno tune it for the current conditions and see what changes they makes based on what they're seeing. Turns out a PO had wired in the WBO2 to pin 55 of the PCM which is a pretty common thing, so now I've got EGR voltage turned on in the scanner. Really hope I can break that mythical 500whp threshold I'm rubbing up against!
    Dec 2013
    Slidell, La.
    1,015
    THE FACT THAT THERE IS ZERO TIMING PULLED LEADS ME TO BELIEVE THE KNOCK SENSOR CALIBRATION NEEDS TO BE ADJUSTED. IT COULD BE THAT THE TIMING IS JUST RIGHT, BUT I ALWAYS LIKE TO SEE KNOCK SOMEWHERE, TIP IN, WOT, DURING SHIFTS, ETC. WHEN I SEE KR, IT TELLS ME THE SYSTEM IS WORKING, I WOULD RATHER IT BE A LITTLE AGGRESSIVE, THAN NOT AT ALL. I JUSUALLY LIKE TO FIND MBT ON THE DYNO, AND JUST HAVE IT TOUCHING THE KNOCK SENSORS AT THAT POINT.
    JUST THIS PAST WEEK, I DID AN LS3 IN A 2002 CAMARO, HAD TO INCREASE SENSATIVITY 45% to get it to register kr at 31 degrees, which is high for an ls3
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
    Jun 2014
    Boulder, CO
    202
    Being a bit rich won't lose much power and is on the safe side. LS engines don't need nearly as much ignition advance as old school engines but they do like what you can give them. I'm no help on Gen 3 -> 4 knock sensor calibration so if it was my motor, I would hesitate adding ignition advance until I was *sure* I could trust the knock sensors to detect knock.
    Apr 2019
    Parts store
    476
    Quote Originally Posted by pannetron View Post
    I must say invest in some kind of knock monitor to calibrate your factory settings if the bore size has changed. Here is an example and not expensive compared to the damage knock does.
    The Link G4 Knock light is good insurance @ < $200. https://tunertools.com/products/link-g4-knock-light
    HOW DOES THE NEW KNOCKLINK G4 COMPARE TO THE OLD?
    The old KnockLink was admittedly crude in its operation, the displayed value was proportional to engine noise and knock could be seen as an addition to this. The new KnockLink uses advanced signal processing techniques to determine actual engine knock, normal engine noise is completely discarded.
    The new KnockLink is housed in an anodized black aluminum enclosure, providing sleek looks along with high durability... steps ahead of the old KnockLink.
    Operation is simple. The colour of the LED represents four different modes:
    Dim Blue - KnockLink is powered, waiting for the engine to be started
    Flashing Blue - KnockLink has detected the engine has started and is now calibrating
    Dim Green - KnockLink is adapting to the engine's noise profile and listening for knock
    Flashing Red - KnockLink has detected knock. Avoid large throttle openings, seek professional advice
    Without another detection to "be *sure* " it was real knock you are playing with fire. IMO
    Jun 2020
    Myrtle Beach, SC
    From my understanding that is only if you have disabled your MAF to tune in SD mode which the ECU defaults to low octane mode .
