Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
Thread: First drive after flashing always acts weird, anyone else experience this?
  1. #21
    Dec 2019
    DFW, TX
    124
    My car doesn't have initial and minimum tables, just multipliers for each cylinder and transient and eq multipliers. You made it seem like there was a way to set them with the scanner, not in the editor.
    As for Bray,
  2. #22
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    No secrets to hide. If your ecm has to relearn before it acts right, then something is not properly calibrated. Unfortunately im not going to type out a long how too on tuning, as that has been done many times over in this forum. My best advise is to pay attention to what is giving fits, and find out why. Asking vague questions but expecting direct answers isnt realistic.
    Post a tune file, then post logs showing it acting up, then a log after its running fine. And give us something that we can see and give you better advise on
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
  3. #23
    Feb 2020
    Central VA
    54
    I have never had the issues you are describing. I have been tuning my car for about 2 months but very gradually. I did notice a starting problem so after flashing, I turn off, then turn on(not starting) turn off then start normally. Something doesn't work properly the first start so the extra works perfectly.
    2017 Camaro SS, Flow Tech axle back, Roto Fab, Nick Williams 103 TB, BBK long tube headers, Magnuson 2650, Snow Performance Water/Methanol Injection.
  4. #24
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Quote Originally Posted by ShaneB View Post
    As for Bray,
    If you have a GenV V8 (the section we are in), then you should have the mentioned tables. Click on Edit, View, and Advanced to make sure that you have HPT showing you their full variable set for the vehicle in question.
    Steve Williams
    TunedbyFrost.com
  5. #25
    Aug 2014
    Central, LA
    737
    Quote Originally Posted by Frost View Post
    I have never seen initial and minimum on a gen 5 like it exists on gen 4.
    Care to share a tune that has them?
  6. #26
    Dec 2019
    DFW, TX
    124
    Phew, thought for a second my 2018 Camaro SS with a Gen V LT1 V8 that I've been tuning for awhile now wasn't a Gen V. That would've been embarrassing.... No need to be condescending and insult peoples intelligence buddy. I'd like to see a tune with those tables too.
  7. #27
    Advanced Tuner jsllc's Avatar
    Sep 2015
    Bozeman, MT
    701
    Quote Originally Posted by mbray01 View Post
    when properly calibrated, an ecm shouldnt need any type of "reset" outside of whats done within the software.
    the purpose of a proper calibration is tell the ecm what it needs to know, so it doesnt have to "learn" anything before it acts right. in the past there were a few issues(injector tip temp) that created artificially rich conditions until a certain counter finished, or a wide open throttle blast. but those are non issues, when you address them before you even start
    Thank you. Not that you need reinforcement for what you already know. This BS floating around the forums of zeroing or ignoring injector tip temp needs to be squashed. Dead on. If you want to tune best to know what things do and how to adjust them (if they are exposed by the tools).
    2012 ZL1 - Maggie Heartbeat, Port & Polish Heads, Custom Cam, Custom rotating assembly, steel sleeved LS9, No NOS and No water meth. 16psi
    810rwhp and 820rwtq 91 Octane 6400 rpm
    948rwhp and 951rwtq 105 Octane 6400 rpm
    999rwhp and 997rwtq on 60% Ethanol 6400 rpm
  8. #28
    Aug 2019
    22
    My car does the same thing. First drive after changing the tune I get some knock (only a few degrees though). After the first drive I get none at all. 2017 Camaro ss
  9. #29
    Jan 2006
    Richmond VA
    1,950
    Quote Originally Posted by sevinn View Post
    Had to be one of those cracked out days or something.... looking for blame lol.
    Steve Williams
    TunedbyFrost.com
  10. #30
    Dec 2019
    48
    I made a similar post on here recently too... My 18 Camaro will read crazy ambient and IAT temps (think double or more) for 10-15 mins after a flash. Its extremely frustrating.
