Results 1 to 13 of 13
Thread: Working on an E78 ecm lean on idle need some help
    Feb 2020
    14
    finished swap instale l96 6.0 with 6l90e all runs good however it is lean at idle. I have read and looked all through out the tune and can quite figure out what i need to change to richen the idle this would be in close loop after it get to temp.
    also has any one been able to get the Efans working i have two swaps with the same set up and i would like the fans to work,,
    'thanks in advance.
    405
    2,316
    Why do you say it's lean at idle? In closed loop up to temp the fuel trims should be trimming it to stoich. Are the fuel trims + ? Even if they are it should be running at stoich.
    Feb 2020
    14
    yes at idle, the fuel trims max out and it still asking for more fuel close loop i get a lean even and odd bank ces light
    13,559
    What's your fuel pressure?
    Feb 2020
    14
    60 lbs im going to check for an air leak tomorrow
    Feb 2020
    14
    lean idle
    here is a idle scanne log file check it out let me know what you think
    13,559
    What is the intake setup? Factory MAF sensor in a stock size MAF tube?
    Does it have exhaust after the o2 sensors?
    Feb 2020
    14
    4" pipe all the way i side the cab 3 90?s teo 45s all sealed maf is installed with in a foot or so from throttle body
    2 1/4 exaust after shorty headers flowmaster muffler
    13,559
    The stock MAF housing on the airbox isn't 4 inches round so if you made yours 4in then this is where I see your problem.
    You'll have to re-do the MAF curve to dial things back in.
    As a test you could add 5% to the entire MAF airflow table, then see what happens to your fuel trims.
    Feb 2020
    14
    Ill try that a bit and post back here
    Feb 2020
    14
    That was it thank you! Runs way better!
    13,559
    Remember that was just a quick test to see what you need to do. Now you will want to take the time to make sure the whole curve is correct. Ideally using a wideband to make sure fueling is correct at not only part throttle by at full throttle where you will have no fuel trims to correct it.
    Feb 2020
    14
    Absolutely we add till it was adding and or subtracting fuel now it hangs close to 6%+-
    There is a few areas at 10% or so but way better than what it was. Hes going to drive it some then we will revisit.
