Been a year since I last checked on this. Any status update or ETA on when we will have access to the MPVI2s accelerometer data with the pro feature set? Thanks.
u can do it with the maths function, its not live but u can go back and see if acceleration is constant/increasing/decreasing
based on how long it took to get promised features enabled from the original MPVI (Digital/Analog/Standlone logging), it could be years. Is why I didn't upgrade.. I had a feeling it would be the same with MPVI2 and was right.
2010 Camaro LS3 (E38 ECU - Spark only). MS3X running complete RTT fuel control (wideband).
Whipple 2.9L, 3.875" Pulley, kit injectors, supplied MSD Boost-A-Pump, stock pump
LG Motorsports 1 7/8" Headers - No Cats, stock mid pipe with JBA Axle Back
ZL1 Wheels/Tires
u can use this ([8001.113.avg(-1000)]) - ([8001.113.avg(1000)]) the pid is undriven wheel speed, it will generate a number based on acceleration so the higher the number the faster u are accelerating or if it stays the same ur rate of accel is staying constant or if it lowers into negative can see ur slowing down
