Results 1 to 2 of 2
Thread: Average air mass
    Average air mass
    On an ecoboost engine. when datalogging. Is the Average Airflow PID (lb/min) inferred from the Speed density or is it calculated using pressure and temp sensors?
    I found this on a F150 ecoboost forum.
    Airflow #/min = Engine displacement for one-cylinder (.00157 for 3.5 eco) x RPM x # of cylinders/2 x desired load (torque inverse value)
    The person is a known tuner and said the PCM uses this formula internally to calculate airflow
