Results 1 to 7 of 7
Thread: Ford Fiesta ST Template
    Hello fellow FiST'ers!
    I've put together a number gauges to mimic the dashboard of the Ford Fiesta ST. This includes tachometer, speedometer, boost, and temperature gauge.
    See it in action here:
    The template and gauges are available here: https://drive.google.com/drive/folde...SC?usp=sharing
    This does require the use of a special font which is also available at that Google Drive location.
    See this post for directions on where to place the files.
    The Google Drive link also includes a "Big Turbo" Boost Gauge for if you're more likely to be seeing boost pressures above the stock 20psi closer to 25psi.
    Feb 2020
    Thank you so much for sharing this! Downloading it now and giving it a try. You absolutely NAILED this.
    Potential Tuner koroshi's Avatar
    Mar 2020
    Tokyo, Japan
    Gosh yeah! That is perfect !!
    Apr 2020
    7
    Thanks HoboBob. I downloaded your template as I am interested in the static run list on the top right and the time lost/gained in the bottom middle, but I can't seem to find them in the template. Would you be able to share them?
    Quote Originally Posted by fancythathat View Post
    I actually pulled those out since those are more autocross specific rather than specifically for a Fiesta ST. I'd like to clean up the underlying code a bit more on the lap list and sectors before I publish them (still secretly hoping that sectors become a supported feature in RaceRender).
    I did post the Time Delta object from the bottom middle in your other thread though. Hopefully we can get you something there that will be more specific to what you're looking for.
    Potential Tuner Kabaera's Avatar
    Dec 2018
    Clifton, New Jersey
    Thanks a lot.
