Page 4 of 4 FirstFirst 1234
Results 61 to 67 of 67
Thread: Any chance HPTuners will run on a Mac?
  1. #61
    Advanced Tuner oakley6575's Avatar
    Aug 2011
    421
    Quote Originally Posted by LSxpwrdZ View Post
    The easiest way I've found is to use bootcamp to partition the hard drive and install W7 on the partition. I then use REFIT to give me a boot menu on startup to select Mac or Windows.
    This is how I did it. Bootcamp was so easy and windows 7 cost me right around $100 iirc.
    2003 Chevy Silverado Daily Driver, 408 Iron Block,
    LS3 Heads/Intake, 231/239 114, 4L80e, Yank SST 3200.
  2. #62
    Tuner BlackGS's Avatar
    Aug 2007
    Central Jersey
    170
    Quote Originally Posted by Mobius View Post
    I have a macbook air with parallels and just ordered hptuners... we will see how it goes!
    I have been using parallels 7 with HPTuners running under Windows 7 without any issues.
    2000 Regal GS | Twin-Charged T72 | HPT Pro + PLX Wideband | 12.55 @ 110 on 15psi | Now running 20psi on E85!
    1998 5.9L Durango | Powerdyne supercharger @6psi | Mesa Headers | Gibson Cat-back | 1.7 RR's | Tuned PCM | Ported Heads | Custom TB & Intake | Custom fuel rails | Rebuild coming soon...
  3. #63
    May 2009
    479
    So there will never be MAC support? I'm running it through bootcamp and it sucks.
    2018 Infiniti Q60s
    2004 350z/LS2: ERL 434ci, 11.8:1,TFS245cc,262/266@113+3,Fast102,NX 102 plate,60#injectors/return w/twin 255s
    Old setup: CNC'd317s, Fast 102, 228/228@114, PT88,83#injectors/full return system. 10.84@138
  4. #64
    Tuner Joe_G's Avatar
    Oct 2006
    Ft. Lauderdale, FL
    115
    Works perfectly for me using parallels. Zero problems. Only bad thing is I have to leave the lid open when scanning so I worry a little that it will slide off the seat during a run and break. Cannot close the lid on a Mac or it goes to sleep.
  5. #65
    Dec 2008
    on the Dyno
    1,825
    Update on mine, I removed REFIT as my boot option because it causes issues with the screen brightness when in windows. Now once the computer is started up I just hold the "Option" key down and roughly 5 seconds later it pulls up current found bootable drives to boot to. So you can select Windows or Mac. I personally love mine. Probably wont ever own a different computer.
    Located in Central Kentucky
    ShorTuning
  6. #66
    Quote Originally Posted by BlackGS View Post
    +1
  7. #67
    bootcamp install windows 7 I use it all the time works like champ
    for lsxpwrdz did you know you can power on the mac hold the option key and select which partition to boot from?
    Hope this helps
