Originally Posted by
NigerianS197
Good Morning All,
(Sorry If this is too long, but I'd like to be as detailed as possible)
This last weekend, my friend and I Installed some LTH with an O/R H pipe on my 2008 Mustang GT. It's both of our first times doing any kind on header, so you can only Imagine how long it took, but on Sunday afternoon everything was nice and secure. Naturally, since the my car has a new exhaust system, I needed a tune to keep the car from running poorly. I found Eric Brooks' write up on how to tune an S197 GT, and followed that to a T since my mod setup is similar (minus the CMCV Deletes). The only thing I didn't mess with was the the Timing since I wanted to get a better understanding of what I'd be doing before I change it up on my car. So I load the Tune into the car, and she fires up immediately without an issue. Great! We saw no visible exhaust leaks at the time, so I let the car run for about 10 mins. I shut her off, and Turn her back on 10 mins later, still no startup issues. Great! She has a smooth Idle and nothing apparent is jumping out. So the car runs fine for 20 mins. I resume the turn off and then on sequence 20 mins later, and she still fires up with no issues, So I got out for a Drive. I'm not really getting on the car, but I am testing to see if there are any warnings signs. The Drive goes very well (the exhaust sound was amazing), so I turn to head back to the starting point, and the Car goes limp and dies completely (got to about 3000-3150 rpm). The Drive had only been for about 10-12 mins at that point in time, and I wasn't really on the throttle that hard at all (about like 45%). Two days later, the car still won't start at all. I've already ruled out the Battery/Alternator since they are both connected and passed a continuity test, I don't believe it's the starter since the engine does want to turn over, but just can't/won't but I could be wrong on that. I've changed the fuel filter to a new one, and I've pressed the EFI reset switch on the car as well. I don't think it's the fuel pump, since I do hear the priming noises, but I may be wrong. The only parts that I haven't checked are the fuel rails, spark plugs, plugs, and other similar things. The Intake does suck in air upon start up attempt so I don't think that's the issue. Any Ideas on what else I could do? Flash in the stock again and try that? New tune rewrite? Has my PCM bricked itself somehow? What else should I take a look at? Also as a side note, The car isn't throwing any codes. I find that strange since the only code I turned off was the P0605 code. I tried checking the DTCs with both HPTuners and a code reader and both gave me the same result. Thanks in advance.
