Ok so spring is here lol. Adding a 100 shot this spring, then going by 50's to a 200 shot. P01 PCM, Looking for advise on what to change... timing 2* per 50 shot, AFR spark advance correction table, PE EQ Ratio amounts through the rpm range, Throttle hot %, and any other adders to think about. Considering the shot to be right off the pedal at first then with 200 shot go to button when it hits 2nd gear and all the way through!!! Thanks for your help!
77 Camaro
Nitrous Express GM LS 3-Bolt Plate Nitrous Systems 20935-10
2002 5.3 stock w/truck intake
706 heads with springs
Stock injectors
Walbro 255 fuel pump
LS6 cam
Shorty headers with high flow cats
3400 stall behind built TH350
410 gears
26" Tire
