6mt 5.0 with FRPP2 intake and tune on 93 octane pump gas. catback exhaust, steeda poly engine mounts(soft ones) and upr catch can.
couple of questions about this tune. Have you guys that have logged it seen this much knock during heavy part throttle and then wot? it appears lowering throttle enrichment to something other than 90% would help as the part throttle knock seems to be tied with heavy load and then stoich. thoughts? arent these timing maps built around stoich, 100 degree air, though?
for part throttle im getting areas where the pedal position and throttle position are 40% out from each other. look at log 1 time stamp 1:26 on the first log. is this normal??
time stamp 3:55 on 1st log is a mid third gear pull with a few cylinders maxing out allowed KR. i have noticed it is not always the same cylinders each time which gives me some hope its not one cylinder always getting hot but #7 is more common than the rest it seams
time stamp 3:56 on the 2nd log also is a 3rd gear pull with traction control off.
idle stumble and me catching it with a bit of throttle is in log#2 at 2:31 time area. reminds me of a bad dashpot that lets the throttle close too much too soon.
Im likely not logging the right channels to see what is needed, please adv what else should be logged to help show this hiccup if so.
any thing you see feel free to comment on, still learning the best channels to log and then the sample rates on them as well.
