Thread: changing my speedo
    Sep 2006
    203
    changing my speedo
    i am working on learning how to tune my 98 s10 before i mess with the ss so i don't screw it up.. any way i want to raise the spedlimiter, what is the speedlimiter2 about?? i moved the limit to 150 and the resume to 110, but the truck only gets to the origional 94 and stays, it still has motor but something is holding it, either timing, a limiter, fuel,, i dunno what else would need to be changed?
    28,273
    speed limiter 2 is usually for reverse.
    Advanced Tuner gman4dx266's Avatar
    Jun 2006
    Cape Coral, FL
    860
    change both limiters, make sure you also kill the fuel cut @ 94 too. that sudden cut hurts you.
    Sep 2006
    203
    my fuel cuts are set by rpms and not mph, i have the limiter at 150,resume at 140 and the speedlimiter is at 5600rpm way above where it still seems to be cutting out?
