Hoping someone can point me in a good direction.
Car:
2015 C7Z A8
Weapon-X cam with variable cam delete
Whipple blower
Low side fuel kit
Issue:
I seem to be running into torque model or management issues. Commanding 99% throttle on a run, only getting 47% actual. As a result, not getting any boost. Everything else seems to be OK for now. Still working on SD tune, but I need to get my torque issue sorted so I can get into the higher pressure ratio areas on the map.
I've attached a couple logs with most things torque related logged. Also attached the tune. Can anyone help point me into the direction I'm missing?
C7Z_torque_issue_3.hpl
C7Z_torque_issue_2.hpl
C7Z_torque_issue.hpl
TUNE_0015.hpt
