Results 1 to 2 of 2
Thread: Ls1 injectors
    Nov 2019
    8
    Ls1 injectors
    I have a fbo ls1 gto running stock ls6 intake what injectors are you guys running and/or recommend.Can i go with 80lb injectors for future boost applications of should i get around 40lb ones.And which injectors are hard to tune.
    13,559
    Cheap injectors will make you run in circles.
    I suggest buying from places that give good quality and data with them upon purchase. Anything from Fuel injector clinic, fuel injector connection or even Deatchwerks will all offer that.
    Buy larger injectors than you currently need isn't out of the norm. Pick the size you want based on the future horsepower goals on whatever fuel you think you will be running. 60lb/hr and 72lb/hr injectors will support a lot of power on pump gas.
