Thread: New Build, New Tuner, Wont Idle
    Mar 2020
    10
    So I got a 73 Camaro with a "built 5.3", supposed to be turbo but not tuners/fab shops in norcal wanna pick up their phones or answer emails so here I am doing this myself without the turbo cause i miss driving my car
    99 5.3 LM7
    55lb FiTech injectors
    FiTech Intake
    102mm throttle body
    LS3 MAF
    BTR Stage 2 turbo cam-- 226/231 .605"/.598" 113+4
    BTR .660 lift springs
    450 lph walbro fuel pump
    LS7 Lifters
    No Afr Guage
    Stock pushrods
    So Im having an issue with the car not even holding an idle. Sometimes itll take a minute to crank before it starts, but itll start after i start scanning and then crank.
    It'll run for about 3-4 secs max and then just die. Im listening to it while it cranks and my guess is that its igniting at the wrong time. Im also adjusting the screw on the throttle body to allow it to open a little, but I dont know if thats helping much. I know VATS is removed so I dont think thats the issue. Other than that I don't really know what direction to go in tuning wise.
    Any help is greatly appreciated, can't wait to get this thing on the road and hearing the cam is just too much of a tease.
    -Jesse
    Camaro1.2CAM.hpt
    Feb 2017
    miami
    1,799
    gasoline?
    If you have a ton of mods you need a wideband
    If it had a stock tb stock intake stock manifolds stock cam etc.... you could use most of a stock file and wouldnt need the wideband so desperately
    connect wideband a/f to the hptuners scanner so you can post logs with wideband data. It only takes a minute.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    there are tons and tons of write ups about adding proper injector data, getting a base file working, and how to get idle working enough to get the tuning process started. do some searches, there is a wealth of knowledge, here, and its all free, if you spend a little time searching. turning the throttle screw is likely giving you the opposite effect then what you desire. once you turn it past about .65v it kicks it out of idle, and thinks your holding it open with your foot, at which point you loose the ecms "idle control"
    your biggest issue is injector data, and calibrating the airflow models, because your likely crazy rich right now
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Sep 2015
    38
    try this file plz and we need datalog also
    Camaro1.2CAM.hpt
