If set up for speed density and Im running rich(-21) hist, I adjusted VVE by x.95. It moved to(-16) at idle
Then bumped to x.90 and no change?
Is there something else in play here?
J
J
If you post the tune, other people can take a look and give you an answer without having to ask a hundred questions back and forth - 'did you set this to X? what about turning off Y?' etc.
Ive never come across one that didnt work, when properly set up. Do you have maf failed correctly? Are you making changes, then smoothing the table, if you are, its likely smoothing your changes back.
Post your tune and lets see whats going on
Michael Bray
Rusty Knuckle Garage
Slidell, Louisiana
20yr Master Tech.
Advanced Level Specialist
GM World Class Technician
Shop Owner
Here are the logs as adjusted.
The wide band wasnt connected correctly on some.
But i reran them and it stayed the same.
J
3.11 x.95.hpl3.11 x.95 and x.95.hpl3.11 x.95 and x.95 x.90.hpl3.11 x.95,x.95,x.90,x.90.hpl
The tune.
If im missing something here i wouldnt be surprised im in the garage door cracked(-9 degrees this morning)and the fumes are ruff.
This is the tune at the x.95....them again x.95 on the VVE table
Jas
3-11 Jason Stock tune 08 Suburban .95x another .95x .hpt
Not stock tune just file name
You only changed the first VE table. You'll need to at least change the first and last VE tables if you aren't going to use DOD. I change all four for completeness sake.
Manifold Switch Closed
Manifold Switch Closed (DOD)
Manifold Switch Open (DOD)
You also need to click the Calculate Coefficients button after changes are made to each table.
I have no DOD
I do calculate Coef.
Ill try switching open and closed tables next.
Its a e38 if that matters.
Jas
We have a winner!
Mr Kevin87turbot
Changing the both open and closed.
The numbers are moving now.
Thank You Sir!
