Hi all,
Ive got a 6.0 L98 / 6l80e combo with E38 /T43 ecms.
Its in a landrover so just has a small cam - VCM532 - 215/223 - .583/.583 @112.
When I first got it back from the tuner, it really was pushing on the brakes and surging at idle in gear, like its pulsing forward, which when its cold make it hard to stop.
I've had the tuner have another look at it, and they lowered the idle down to 680 (from 720), which helped a bit. But the main issue is that it pulses forward when in gear at idle, so that makes coming to a stop annoying cause the brakes can't smoothly bring it down to a stop.
The timing looks to jump around a bit more than I would have thought necessary, but just not sure what things to try to stop it surging?
Also, Not sure if the way its setup is making less vacuum than it otherwise could with this size cam.
I've attached the tune and a quick scan file below, and would appreciate any help.
Thanks in advance!!
perentie - retune.hpt
newtunetest.hpl
