99' frc vette ls1, cam, exhaust, ls6 intake manifold, aem wideband
I tried to take it nice and easy, swapped in a junkyard unlocked ecu, loaded a factory tune from the repository to verify parameters, enriched fueling by 15%, disabled close loop via coolant temp, as well as lt/st fuel trims. Figured i should be safe to run off the maf, dial in the curve and move on to VE tables. Except the big sticky hit the fan and Im frankly a bit too panicked to tap into higher level reasoning that might actually allow me to help myself. The car starts seemingly normal, after a couple seconds starts to sputter as stalls out. I have no idea what my wideband PID math is measuring in the scanner, the actual lambda readings were .8 when i started the car which held for a few seconds followed by a steady leaning until it sputtered out. I will fix that PID issue but Im terrified to even start the car since I dont know what the hell happened Ive attached my tune and the short startup scan, Sorry in advance for my dumpster fire introduction
