Results 1 to 11 of 11
Thread: VCM SCANER UNhandeled exception error after updating VCM SUITE.
    Jan 2020
    14
    Help after Updating VCM SUITE getting Unhandled exception error. program opens but cannot use, will not connect to anything. These are the details of the error.
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
    at ...(Int32 )
    at ..(? , Func`2 , Func`2 )
    at ..?()
    at ..?()
    at ..?()
    at ?..?()
    at ..( ?, ? )
    at ?..?(EventArgs )
    at System.Windows.Forms.Form.CallShownEvent()
    at System.Windows.Forms.Control.InvokeMarshaledCallba ckDo(ThreadMethodEntry tme)
    at System.Windows.Forms.Control.InvokeMarshaledCallba ckHelper(Object obj)
    at System.Threading.ExecutionContext.RunInternal(Exec utionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
    at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
    at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
    at System.Windows.Forms.Control.InvokeMarshaledCallba ck(ThreadMethodEntry tme)
    at System.Windows.Forms.Control.InvokeMarshaledCallba cks()
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4121.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    Assembly Version: 4.6.3.0
    Win32 Version: 4.6.3
    CodeBase: file:///C:/Program%20Files%20(x86)/HP%20Tuners/VCM%20Suite/VCM%20Scanner.exe
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    Win32 Version: 4.8.4001.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    Win32 Version: 4.8.3752.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    InTheHand.Net.Personal
    Assembly Version: 3.5.605.0
    System.Management
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    {747e2fc9-000e-45e5-93fd-339b2d0d9cb4}
    Assembly Version: 0.0.0.0
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    Sep 2008
    Australia
    80
    Same deal here.
    Was just Beta doing it for me, now also happens on stable 4.6.
    Going back to an old laptop with an old version
    Mar 2015
    gippsland
    134
    delete all your channels and repoll
    Sep 2019
    16
    I have the exact same issue, is there any repository of sorts for xml file scanner graphs? I need to do some ve logging but cant access the parameter tree so maybe this would be a temporary workaround?
    Mar 2015
    gippsland
    134
    delete all your channels and repoll the channels.
    this will fix it. its a pain but is all i could get to work.
    Sep 2008
    Australia
    80
    Just got mine sorted.
    I deleted Beta. Re-downloaded it. (wouldn't update to the latest version using the method via the "help" icon, then "about"
    Then as tris909 mentioned, individually delete all your PIDS then reload.
    As the stable version was doing the same for me also I pressume this method would work there also.
    Support said it was .net framework causing the issue but I have the latest .net framework ...
    Sep 2019
    16
    Apparently I'm doing something wrong here. It would be awesome if you guys could break it down further for me. I delete every PID (i assume this is what's meant by channel?) And every custom graph. When I click connect to vehicle and the pid list populates is this a "repoll"? After that i still receive the same error message. Thanks guys.
    Sep 2019
    16
    anyone?
    Sep 2002
    Chicago, IL
    6,395
    Please open a support ticket. We'd like to look into this for you.
    https://support.hptuners.com/
    We got this guy Not Sure, ...
    Sep 2019
    16
    FIXED! The last instance wherein I deleted the suite I searched my harddrive for any associated files and deleted a saved vcm scanner setup file that I had forgotten about. With that out of the way the slate is clean and everything works!
    Jan 2018
    16
    i am on the road and unable to start a ticket, has anyone else started one
