Hi Everyone I am swapping a 4.6L 3V with manual trans out for a 2006 Mustang GT into my 57 Mercury truck and I am having a no start issue.
I could get it to stumble for 2-3 secs if I unplugged the Cam Position Sensors.
Engine is stock.
I have new ford racing 24lb injectors,
new plugs,
new coils,
new TPS,
New Crank Position Sensor,
New Cam Position Sensors,
Stock replacement MAF,
Air Raid intake tube,
Return style fuel system with in tank fuel pump wired independent of PCM. I have a mech regllator and 42psi of fuel pressure.
Harness is a 2006 harness that has been reworked by a guy who does this all the time.
Only running front O2 sensors
Stock Ex Manifolds,
No EVAP,
PCM has been tuned with HP Tuners. Pats has been turned off and confirmed.
I only had 3 codes. P0685, P0690, P1000.
I have purchase a second PCM and it won't run still. Oddly the accelerator pedal won't respond with the second PCM, we can see the voltage change when the pedal is pressed but the throttle body motor won't move.
I am at a stale mate. I have had a reputable tuner come out and review the set up and we have made some changes but we are still getting a no start or a stumble if we turn the fuel down so low that it shouldn't want to start but tries.
I have a voltage at the CKP and can see an RPM most of the time on the logger, my fuel injector pulse is sporadic with the Cam position sensors plugged in but with them unplugged it is steady.
I am starting to wonder if I have 2 bad PCM's or a compression issue or a bad wiring harness...I have pinned the harness out and don't see anything of concern. Engine suposedly only has 15,000km on it.
I'm at a loss. Any ideas or someone with a similar experience?
D
